Discussion topic: No signal on comedy central
Message posted on 24 Jun 2023 01:49 AM
In the last week or so, I've noticed I'm not getting Comedy Central HD or Comedy Central Xtra on my Sky Q box or mini box. Comedy Central +1 seems to be working, but it's a bit frustrating. Checked the signal in the secret settings menu and strength is 80 and quality is 90, so I can't see it being that. Anyone any ideas?
Message posted on 24 Jun 2023 11:46 AM
Re: No signal on comedy central
@Andrew+Millar Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 24 Jun 2023 12:45 PM
@Laing1 yeah, should've mentioned that in the question. I've done the old, "have you turned it off and on again?" Thanks.
Message posted on 24 Jun 2023 12:57 PM
@Andrew+Millar are you getting any messages when you go to these channels what do you see on the channel ?
