Discussion topic: No signal on bbc1 and itv2
Message posted on 31 Jul 2023 08:31 PM
Hi
for the last few days I've had an error message for bbc1 and itv2 which says that there is no signal, all other channels are fine. I've tried turning my sky q box off and on a few times, but makes no difference
any advice would be greatly appreciated
Message posted on 31 Jul 2023 08:34 PM
Re: No signal on bbc1 and itv2
@ben.smith
”No signal” tends to be a message from your TV. A “no satellite signal” message relates to your Sky box. Take a look at the troubleshooting on the appropriate section of this link. .
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
You may then need to contact Sky and arrange for an engineer to check the alignment of your dish.
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
Message posted on 02 Aug 2023 07:38 AM
@Daniel0210 Thank you very much, really helpful 👍
