Discussion topic: No signal on TNT Sports or Premier Sports 1
Message posted on 26 Jan 2025 08:34 PM
Whilst there were lots of problems over the weekend with the storm. Things are pretty much back to normal except for TNT Sports and Premier Sports 1. Premier Sports 2 is okay.
I've tried all the usual rebooting and restarting.
Any ideas?
Message posted on 26 Jan 2025 08:42 PM
Re: No signal on TNT Sports or Premier Sports 1
Any ideas?
@JMRD34 what message are you seeing when you try to watch these channels if its no satellite signal then your dish may have moved slightly and you will need to have your dish re-aligned
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 26 Jan 2025 08:57 PM
thanks.
.....This channel is affected by a problem with your satellite signal.
Message posted on 26 Jan 2025 09:34 PM
@JMRD34 wrote:
thanks.
@JMRD34 in that case i'd contact Sky in the first instance
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
