Discussion topic: No signal for satellite
Message posted on 20 Feb 2024 08:17 PM
I've checked my connection & WiFi but I still have no satellite signal
Message posted on 20 Feb 2024 08:37 PM
Re: No signal for satellite
@Willow2016Your satelitte signal does not come through your broadband. Do you have Sky Q or Sky stream or Glass?
Message posted on 13 May 2024 06:39 PM
: No signal for satellite using sky q
Message posted on 13 May 2024 06:48 PM
@NW4
If a message is displaying ”No signal” it tends to be from your TV not being on the correct input (check the HDMI cable between the Sky Q box and your TV)
Any “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
