Discussion topic: No signal for TV
This message was authored by: Tasha07
No signal for TV
Hello,
For 3 weeks our signal has been playing up. All channels are constantly freezing, no sky recordings are working.
Re: No signal for TV
@Tasha07
No signal or no satellite signal?
A message displaying ”no signal” tends to be from your TV.
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
