2
This discussion topic has been answered Discussion topic: No signal at a flat with communal dish
This message was authored by: LP2383
Recently moved into a flat, which has a communal dish.
plugged in the box to the corresponding wall connections with the correct wires, however, it says no signal. I've moved several times in the past and plugging it all in has never been an issue until now.
box works fine at old home, as I've tried it there since. Connects to the WiFi fine and on demand and catch up work fine. Nobody in the block has reported any issues.
am I missing something?
This message was authored by: Laing1 Answer
Re: No signal at a flat with communal dish
@LP2383 i'm guessing your previous address you had your own dish
If so you will need to do the following as you need to change settings on the main Q box to work with a communual system
you need to enter the engineers menu
To enter the engineers menu do the following
press the home button then scroll down to settings and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
Select the LNB Type & set to SCR
After changing the LNB type power down your SKY Q box and restart it for the change to come into effect
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for LP2383
Thank you! That has worked, that's great.
