Discussion topic: No satilite signal with over 40 channels
Message posted on 16 Jul 2024 10:58 AM
I have "No satilite signal" on over 40 of my channels on my sky Q
Message posted on 16 Jul 2024 11:22 AM
Re: No satilite signal with over 40 channels
@Kiwi2u
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
