Discussion topic: No satellite signal
This message was authored by: Zeezee74
No satellite signal
Hi for no reason whatsoever my sky has suddenly telling me I have no satellite signal. I can't watch anything including downloaded things. My other half can watch YouTube through the mini box but the sky Q won't do anything. Any help greatly appreciated.
Re: No satellite signal
@Zeezee74
If it’s a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️ a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News).
▪️following adverse weather wait times for an engineer will probably be significantly longer
Avatar for Zeezee74
Level 0 icon
Thankyou so much, I just don't understand why my husband can get YouTube and Netflix upstairs through the Sky mini box but I can't get anything, not even pre recorded.
