Discussion topic: No satellite signal
This message was authored by: Ian239
No satellite signal
I have WiFi but it says I have no satellite signal problem with all channels this has been happening for 2 months still paying for it but no sky be glad when my contract ends and I can go elsewhere
Re: No satellite signal
@Ian239
If it’s a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️following adverse weather wait times for an engineer will probably be significantly longer
