Discussion topic: No satellite signal
This message was authored by: Star+73
No satellite signal
Hi I have no satellite signal going into my tv
Re: No satellite signal
Hi @Star+73   The satellite signal goes into your Sky Q box, not your TV. However have a look Here.
@Star+73
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
