25
This discussion topic has been answered Discussion topic: No satellite signal
This message was authored by: Alfiedog
No signal source ??
Tv won't switch on text says Source freezes all the time when it comes on eventually received a  booster to help. With signal it. Does Not
Re: No satellite signal
We are age 92 & 85 technefobe a we cannot be crawling around the way An engineer would surely we could get better help than texts
Have you given Sky a call and requested an engineer visit?
Re: No signal source ??
It doesn't sound as though this has anything to so with Sky Talk - Sky's landline phone service. Is this Sky Stream? Glass? Or Q?
@Alfiedog
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
@Alfiedog
Advice has been provided on the other thread you've posted on regarding no satellite signal.
This message was authored by: RD54
No signal
@RD54 wrote:
No signal
Hi @RD54   No signal means that your TV is not on the correct HDMI input. The solution is to put your TV on the correct HDMI input for the Sky Q box.
@RD54
No signal and no satellite signal issues are different .
As @MightyQuinn has stated a message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
It’s worth noting that:
▪️following adverse weather wait times for an engineer will probably be significantly longer
This message was authored by: Manir
I have no satellite signal sign on my tv sky box
@Manir
Have you read the post immediately above yours which provides the correct advice.
Answered - Go to Answer
