Discussion topic: No satellite signal
Message posted on 25 Jun 2025 09:27 AM
No satellite signal
Got fibre fitted yesterday but getting no satellite signal on tv checked and everything else working and can download on catchup anything im missing here as was told by sky dont need a dish anymore
Message posted on 25 Jun 2025 09:31 AM - last edited: 25 Jun 2025 09:32 AM
Re: No satellite signal
hi @Caleyblue
Is the SKY Q box still connected to the Satellite Cables from the dish ?
SKY Q still uses signals from the satellite
Having switched to fibre you are likely to have fast enough boradband speed to get all channels over the internet and no longer need the dish but this would mean switching from SKY Q to SKY Stream which is a different product in quite a few aspects.
Message posted on 25 Jun 2025 09:33 AM
That was not said at the time would i need to call sky to get this as person i spoke to said would no longer need a dish to be connected which was what i agreed to when asked as no dishes allowed at this site
Message posted on 25 Jun 2025 09:41 AM
Yes, I believe, to switch from SKY Q to SKY Stream you would need to call
@Caleyblue wrote:That was not said at the time would i need to call sky to get this as person i spoke to said would no longer need a dish to be connected which was what i agreed to when asked as no dishes allowed at this site
If you have a Sky Q box then it will not work without a dish.
Yes, you need to call Sky! You don't need a dish but, as above, you need a different product. (And it's quite different)
Message posted on 25 Jun 2025 10:41 AM
Hi @Caleyblue If you go to sky.com and log on. Then go to TV and select Stream. You can change to Sky Stream on line but it will probably cost more then doing it over the phone.
