Discussion topic: No satellite signal
Message posted on 25 Apr 2025 02:24 PM
No satellite signal
All channels are not working broken pictures on going for 3 weeks now
Message posted on 25 Apr 2025 02:46 PM
Re: No satellite signal
@Shamila
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
