Discussion topic: No satellite signal
Message posted on 04 Feb 2025 09:38 PM
No satellite signal
This is all I’m getting I’ve tried resetting, it’s the same with mini box , tried all the usual resetting the WiFi , turning box off and on
Message posted on 04 Feb 2025 09:59 PM - last edited: 04 Feb 2025 10:00 PM
Re: No satellite signal
@Stephrosalind If you have a No Satellite signal issue on the main SKy Q box no amount of turning off your wifi will help as the channels are delivered by Satellite not wifi.
Check through the following link
Once you get to the end you should be able to book an Engineer.
Message posted on 05 Feb 2025 05:21 AM
@Stephrosalind
Also, if you are connected to a communal dish you need to liaise directly with your building management company / landlord who will have their approved engineers to contact.
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
3 - due to the recent storms there’s likely to be a significant delay in getting an appointment. It may be quicker to contact a local satellite company but that would be at your own expense.
