Discussion topic: No satellite signal
Message posted on 30 Jan 2025 12:48 PM
No satellite signal
No satellite signal notice appearing on my screen. I've tried all the recommended steps to reboot etc but nothing works. Service Check is showing everything working.
Message posted on 30 Jan 2025 12:54 PM
Re: No satellite signal
Rebooting won't resolve it.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
3 - due to the recent storms there’s likely to be a significant delay in getting an appointment. It may be quicker to contact a local satellite company but that would be at your own expense.
