Discussion topic: No satellite signal
Message posted on 12 Jan 2025 01:47 PM
No satellite signal
Hi my satellite signal on my sky Q box has been off for the last 5 days and still won't work
Message posted on 12 Jan 2025 01:49 PM
Re: No satellite signal
@Steven1970
If you are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s almost certainly a dish alignment issue so check the troubleshooting in this link
It’s worth remembering that a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
