Discussion topic: No satellite signal
This message was authored by: Billy2411
No satellite signal
It shows on screen that I don't have a satellite signal
This message was authored by: Christine8606
Re: No satellite signal
I have no signal as well. Is it the weather
@Billy2411  You posted this in the broadband forum, a No satellite signal has no relevance to Satellite delivered channels, which box do you have Sky+HD or Sky Q?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for Billy2411
I have sky Q
@Billy2411 wrote:
I have sky Q
Start here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
You may well need an engineer to check the dish.  However, the lead time may take you past Christmas - you could consider paying a local firm who may be available quicker.
