Discussion topic: No satellite signal
Message posted on 30 Nov 2024 07:07 PM
No satellite signal
Signal was interrupted briefly a couple of times this afternoon. No signal at all this evening. Is anyone else having this problem in W14?
Can't see an issue with my box or cables, rebooted and checked connections.
Message posted on 30 Nov 2024 07:13 PM
Re: No satellite signal
It has nothing to do with your postcode. If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
