Discussion topic: No satellite signal
This message was authored by: ailbhe1661
No satellite signal
No satellite signal is coming up on my sky tv
Re: No satellite signal
Start here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
@ailbhe1661
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in the link provided above. It may give you the opportunity to arrange an engineer to check the alignment of your dish. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
