Discussion topic: No satellite signal
This message was authored by Daniel781 This message was authored by: Daniel781
No satellite signal
I'm currently not getting a satellite signal in meath. Anyone else having this issue?
Re: No satellite signal
@Daniel781  You posted this in the Sky stream forum however Sky stream does  not use satellite to receive channels.
If the message is no satellite signal it's likely to be a local issue such as your box or dish.
This message was authored by Daniel0210 This message was authored by: Daniel0210
@Daniel781
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
