Discussion topic: No satellite signal
Message posted on 14 May 2024 10:47 AM
No satellite signal
My tv says no satellite signal
Message posted on 14 May 2024 10:50 AM
Re: No satellite signal
@Arsenal19831
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
