Discussion topic: No satellite signal
This message was authored by: Russ2468
No satellite signal
No satellite signal showing so unable to get on sky
Re: No satellite signal
@Russ2468
If a “no satellite signal” message is displayed look at the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
@Russ2468
Your duplicate thread has been removed. It's not needed as you have this one which has already been answered.
This message was authored by: ivantasha
Ye were the same here
@Russ2468  The problem wil be your end, if the was a problem at Sky's end the forum would literally be flooded with posts.
Tried the troubleshooting advice above?
