Discussion topic: No satellite signal
Message posted on 08 Sep 2023 09:31 AM
No satellite signal
I literally have no satellite signal on my sky q box just a blue screen
Message posted on 08 Sep 2023 10:23 AM
Re: No satellite signal
If there is no message saying No Satellite signal then it is likely that it is a different issue.
Check that the HDMI cable is correctly fitted both ends and ensure that you are selecting the TV set HDMI input relative to the Q box.
Then try a reboot of your Q box.
