Discussion topic: No satellite signal
Message posted on 25 Jul 2023 09:30 AM
No satellite signal
Haven't had a satellite signal for a few days now can you tell me why this is and how long until it'll be fixed.
Message posted on 25 Jul 2023 09:34 AM - last edited: 25 Jul 2023 09:35 AM
Re: No satellite signal
@PamelaT73 If you have a No satellite signal then the issue is either with the setup/dish you use or the box, it won't correct itself, if it was a wider outage I.E all of the UK with no satellite signal the forum would be flooded with posts.
Try these steps and follow until the very end, if not resolved you should be able to book an engineer.
