Discussion topic: No satellite signal
This message was authored by: lisa20043
No satellite signal
I have a sky q box, I've had it for years no issues up until now.
Ive done all the steps as advised and I have zero satellite issues. Will a new box fix this issue or not? I'm unable to use any of my sky services at the moment, just the extras that I pay (third party apps).
Re: No satellite signal
Start here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
unlikely needs a new box - dish alignment/issue more likely.
@lisa20043
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on the link already provided.
It’s worth noting that:
