Discussion topic: No satellite signal
This message was authored by: She8
No satellite signal
My sky q is not getting any satellite signal. I have moved the main box and used a extension cable which I have used before with no problems. All connectors are fixed correctly
Re: No satellite signal
@She8
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
This message was authored by: Godfrey
@She8   It might be worth carefully examining the ends of your coaxial cables for bent pins and stray strands of the outer screen shorting to the central pin.F type connector.jpg
Does it work if you take the extension cable out of the equation?
