Discussion topic: No satellite signal
This message was authored by: Christine+cm
No satellite signal
Hi. We have no satellite signal since yesterday. Have done all the checks and reboots. Wifi working fine. Anything else we can do?
Re: No satellite signal
@Christine+cm
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Hi @Christine+cm
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
This message was authored by: Roger17
If you have an Apple TV or Amazon firestick you can download the Sky Q app and watch via the the app.
