This discussion topic has been answered Discussion topic: No satellite signal sky Q
Message posted on 06 May 2024 02:44 PM
No satellite signal message done all the trouble shooting and nothing has worked
Message posted on 06 May 2024 02:49 PM
Then you need Sky to come and check the dish/LNB if you have your own dish.
Message posted on 06 May 2024 02:54 PM
Re: No satellite signal sky Q
@Bubblegum
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
