Discussion topic: No satellite signal on sky q mini
This message was authored by: Matt106
No satellite signal on sky q mini despite full internet connection and full connection to main box . Have done full reboot on both boxes . Struggling to know what to do now and engineer not available until 10th Jan . Can you help please ?🙏
Re: No satellite signal on sky q mini
Hi @Matt106
Try a Reset Settings in the main Q box hidden menu.
Once the main Q box is back up and running and you have re paired the remote then try rebooting you mini again.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your Sky Q remote or if this is not working press the standby button on the front of the mini box (Amber led)
