This discussion topic has been answered Discussion topic: No satellite signal on sky q mini boxes
Message posted on 06 Apr 2024 07:02 PM
So I have sky q with two mini boxes. Everything is working fine on the main box, both minis are connected to WiFi (which is working fine) and can access everything that requires an internet connection (eg Netflix, catch up TV, sky cinema etc) but we cannot get a TV signal on either mini box.
the screen is just black and says "No Satellite Signal". We cannot load the TV Guide, nor can we access recordings that are stored on the main box so it seems like it's a problem with the main box not sending data to the minis.
I checked settings on the main box and there is a tick by "watch on sky q mini". I even clicked to reconnect there.
I have unplugged and rebooted all three boxes multiple times, the last time I also unplugged and rebooted the router (also sky). Still no luck.
anyone have any ideas about what else I can do to remedy it?
Message posted on 12 Apr 2024 06:35 PM
So final update. We solved the problem by doing a hard drive reset from the secret engineer settings memo.
this fixed our hard drive problem on the main box (but obviously lost all our recordings) and the mini boxes are now receiving tv signals.
Message posted on 06 Apr 2024 07:38 PM
Re: No satellite signal on sky q mini boxes
Hi @Taxman75
Try a Reset Settings in the main Q box hidden menu.
Message posted on 07 Apr 2024 02:15 PM
Thanks for the reply. I executed the hidden reset and then rebooted the mini box. Unfortunately it still hasn't solved the problem.
Any other ideas?
Message posted on 07 Apr 2024 07:27 PM
So an update. I've just realised that everything isn't working fine with the main Sky Q box. There seems to be a problem with the HDD. We cannot access our recordings and we cannot pause live TV (it says "This service is not available because of a problem with your Hard Disc Drive")
I wonder if this could be part of the problem why we can't get TV on the mini boxes?
Message posted on 25 Aug 2024 11:03 AM
We have no signal to any sky
we have unplugged all mini boxes and rebooted them
there is a nessage on screen
your skyQ mini bix has not been able to connect to the activation server
Message posted on 05 Oct 2024 11:47 AM
Same solution for me. Tried first reset in hidden engineer mode and this didn't work. Did the disk reset and this worked immediately.
Message posted on 15 Nov 2024 09:15 AM
Thanks All. Exactly the same issue for me. Resetting the HHD fixed issue
Message posted on 30 Dec 2024 09:35 AM
A thank you from us too, exactly the same problem and this resolution solved it 🙏
