08 Feb 2024 06:52 PM
My Sky Q mini box says no satellite signal. I have followed all the threads turning off all 3 items Sky main Q and router. Main box works fine. Broadband fine.
I can even access all the apps on the mini box just cannot watch normal TV or recordings. Help please
08 Feb 2024 06:56 PM
Hi @Kt_mccourt
Try a Network Reset on the mini.
