4
This discussion topic has been answered Discussion topic: No satellite signal on random channels
This message was authored by: webtree
My TV is shown ‘ no satellite signal’ only on some channnels BBC, ITV and some more, BBC NI and other regional channels seem to be ok.
Re: No satellite signal on random channels
@webtree
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
@webtree
Avatar for webtree
Thanks, I'll check all that.
Avatar for webtree
All sorted. It was a loose coax cable T the sky box end. Thanks your your advice.
This message was authored by: Susied23
We had this same issue from last night. A whole bunch of channels and some with messy signal. Looks like an engineer visit
