Discussion topic: No satellite signal on mini boxes - main box fine
This message was authored by: bnjoo
My mini boxes all show 'no satellite signal'
I have done all the reboots, checked main box has mini boes ticked, powered all down and back. Still the same messages.
Pls help
This message was authored by: Tom-W19
Re: No satellite signal on mini boxes - main box fine
Hi @bnjoo
On the Main Q box can you go to Settings then Watch on Sky Q Mini Box and select Reactivate.
This will refresh the signal going to the Minis.
Let me know how you get on and we'll help you further if required.
Tom
Avatar for bnjoo
I have the same problem again on all mini boxes
Have reactivated, rebooted, checked software, rebooted router etc.
Pls help
This message was authored by: San2023
I have the same problem the main box has a hard drive problem i tried resetting everything nothing worked replacement box ordered.
My sky mini box is saying no signal again I have tried to reset the box and also go to settings go to watch on sky q mini box and reactivate still the same problem.
The main box there is a signal but the hard drive problem any help appreciated
This message was authored by: Annlynn2
Error MR102
@Annlynn2 wrote:
Error MR102
@Annlynn2 Have you tried rebooting your main Q box ie
then reboot the mini box
This message was authored by: Neil-b1
Hi
did a new sky q main box sort your problem
