Discussion topic: No satellite signal on Sky Q box
Message posted on 07 Dec 2025 10:51 AM
I have a communal ariel as I live in a flat, no one else is having any issues. But my sky has been temperamental for afew months and no won't work at all. The signal checker says it's fine and working but I can't get access to the.
Message posted on 07 Dec 2025 11:07 AM
Re: No satellite signal on Sky Q box
@Ldillon78
If you are seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish).
As you are connected to a communal dish you need to liaise directly with your building management company / landlord who will have their approved engineers to contact.
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 wind and rain can affect the satellite signal and following adverse weather wait times for an engineer will probably be significantly longer.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
