6
This discussion topic has been answered Discussion topic: No satellite signal message on Viaplay 1
This message was authored by: hebaandabby
Is anyone getting a no satellite signal message on Viaplay 1.
Viaplay 2 is fine.
I have contacted Viaplay direct and they say it's the dish misaligned or something.
However I have no problems with any other channels.
I have checked the signal strength and it shows signal strength 80 and signal quality 90.
So I am lost.
Thanks for any advice.
This message was authored by: bob1234 Answer
Re: No satellite signal message on Viaplay 1
@hebaandabbyUnfortunately the signal strength indication does not mean a lot as it is on a specific channel.
Avatar for hebaandabby
  • That's the information that Viaplay said to check
Does Bloomberg work (502)? That's another channel on the same frequency as Viaplay 1.
No signal on Bloomberg
You'll need to book an engineer visit to check the dish alignment.
Thanks it's frustrating especially as all of the other channels work including Viaplay 2.
Answered - Go to Answer
