26 May 2024 06:56 PM
26 May 2024 07:20 PM
Posted by a Superuser, not a Sky employee. Find out more"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following:
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
26 May 2024 08:31 PM
26 May 2024 08:33 PM
Posted by a Superuser, not a Sky employee. Find out more26 May 2024 08:59 PM
SkyQ Danielle
26 May 2024 09:03 PM
Posted by a Superuser, not a Sky employee. Find out moreIf you have a sky Q, if a “no satellite signal” message is displayed, that relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company who deal directly with their approved engineers.
30 May 2024 02:05 PM
Thanks Daniel. My apologies for not replying sooner. An engineer is calling tomorrow.
