This discussion topic has been answered Discussion topic: No satellite signal message and broken/glitchy images on some channels
Message posted on 05 Oct 2025 01:28 PM
The 'no satellite signal' message appears on most channels. On many others the images are broken/glitchy/zoning in and out. I need an engineer to fix the satellite dish. It may have been moved in the recent storm here but is not damaged. Any help would be greatly appreciated.
Message posted on 05 Oct 2025 01:29 PM
@Finola1
If it’s a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️following adverse weather wait times for an engineer will probably be significantly longer
@Finola1
