Discussion topic: No satellite signal from shared dish
Message posted on 31 Aug 2024 06:31 PM
I am getting No satellite signal from a shared dish. TV/Sky was not used for a month.It was working before.
Message posted on 31 Aug 2024 06:33 PM
Re: No satellite signal from shared dish
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it could be a dish alignment issue. As you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact. Check with neighbours as well to see if they are also seeing this issue.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 31 Aug 2024 06:48 PM
Many thanks-have now called an engineer for next week.
Message posted on 31 Aug 2024 06:58 PM
Hi @Panda3
have you checked in your Q box Engineers menu that the Q box is still set to SCR LNB type.
LNB type need to be SCR.
If this is not correct and shows Wideband change it to SCR and edit the menu.
You then need to reboot the Q box to confirm the change.
note: some features may take up to 5 minutes to complete.
