Discussion topic: No satellite signal for 3 weeks
This message was authored by: Diver1
I have had no satellite signal for 3 weeks. Tried turning off sky boxes for over 5 mins. Tried restarting all boxes. Dish does not look like it has moved. We have apps via Wi-Fi but no live tv and no schedule.
This message was authored by: NickNewark
Re: No satellite signal for 3 weeks
@Diver1 Sounds like you've done all the obvious checks. I'd just call Sky and get it reported.
@Diver1
Have you rung Sky in the three weeks as it may be your dish is slightly out of alignment but not necessarily noticeable.
▪️I AM NOT A SKY EMPLOYEE ▪️
Call Sky ASAP as you may only get credit for loss of service from the point of reporting.
Hi @Diver1
You may also need to be aware that the Q box needs a periodic authoristaion signal via the Satellite to keep it 'alive', so there is a chance that it may stop working for the apps
As the others have said best to get SKY  to check alignment etc., if you haven't already.
Avatar for Diver1
I been up to the dish and it seems really tight . Don't think it could have moved,👍
@Diver1
LNB / arm might have.
The dish only has to move a tiny fraction to cause problems, it needs exact line of sight unlike a TV aerial. But either way it needs reporting to Sky so they can find the fault and fix it.
