Discussion topic: No satellite signal but recordings or apps not working either
This message was authored by: Rv11
I have no satellite signal and the message on screen says I can still view recordings, on demand and apps, but recordings or none of the apps seem to be working
Re: No satellite signal but recordings or apps not working either
A satellite signal is required for a 'keep alive'.  Functionality can cease but usually takes many days (or weeks).
Avatar for Rv11
Shouldn't they rely solely on an internet connection?
Nope - it's a security measure so boxes do not operate if disconnected.
Avatar for Rv11
Ah, I see!  Thanks
Avatar for Rv11
Apps seem to be working now,so that's something
@Rv11
If you’re still seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Avatar for Rv11
Thank you. All the cables were actually fine.  It was either the dish (communal one) or a problem with the Q box, as it was also having issues connecting to my router when all other devices were connected fine.
Anyway, it all seems to be working fine again so happy days! 😀
Good to hear @Rv11
Just remember that as you have a communal dish if it reoccurs your first port of call is your building management company or landlord (after perhaps checking if neighbours are also experiencing the same problem).
