Discussion topic: No satellite signal after blackout
Message posted on 23 Sep 2023 07:42 PM
Message posted on 23 Sep 2023 07:47 PM
Re: No satellite signal after blackout
Did you also have storms/bad weather?
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. Be aware that if you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
Message posted on 23 Sep 2023 07:48 PM - last edited: 23 Sep 2023 07:49 PM
@Virgomum You posted this in the broadband forum, however Sky Q uses satellite for live TV so won't be a broadband issue.
You don't say of this is the main box or the mini?
But I would power down both the main Q box, mini & hub.
Then power up the hub, allow to fully reboot, then power up the main Q box, once fully rebooted do the same with the mini.
