Discussion topic: No satellite signal SO31
Message posted on 25 Nov 2024 09:10 AM
2 days of no signal, no normal channels but can use apps, have done all the checks.
Message posted on 25 Nov 2024 09:11 AM
Re: No satellite signal SO31
Start here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
Message posted on 25 Nov 2024 10:09 AM
@MandyJ48
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 25 Nov 2024 10:11 AM - last edited: 25 Nov 2024 10:14 AM
Note that the satellite footprint falls across the entire country (and beyond): prolonged loss of satellite signal is almost always between an individual dish and box(es) and certainly isn't by postcode area.
