Discussion topic: No satellite signal, Cardiff area, since 7:50am
This message was authored by: Jacks00
Lost signal at 7:50am and usual on/off trick not getting anything back. All connections are fine, anyone else lost their signal?
Re: No satellite signal, Cardiff area, since 7:50am
@Jacks00
Satellite signal is either an issue with the whole country or just your set up. It's not a regional issue.
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
@Jacks00  As per @Daniel0210  Satellite signals cover the whole of the UK not just a tiny area, if there was a satellite outage the community would be awash with posts, so much so it would likely end up crashing.
