Discussion topic: No satellite signal AGAIN!!!
This message was authored by: -Steve57
Every time it rains even lightly and sometimes even if its just windy we lose the TV signal all day or for several days at a time! This is the 4th day over this last week we have had no signal and its not even rained all day!! Happening every week for the past few months, fed up of it now. Paying for a service we do not recieve! Looking into changing providers
Re: No satellite signal AGAIN!!!
@-Steve57
Check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️rain and wind may impact the satellite signal.
▪️ a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News).
▪️following adverse weather wait times for an engineer will probably be significantly longer
There is no other subscription satellite television platform.
Sky has no idea your individual reception is failing unless you tell them.
