Discussion topic: No satellite on sky q
Message posted on 21 Dec 2024 02:09 PM
Hi no satellite signal in Edinburgh.
Message posted on 21 Dec 2024 02:12 PM
Re: No satellite on sky q
If you are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s almost certainly a dish alignment issue so check the troubleshooting in this link
It’s worth remembering that a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 21 Dec 2024 02:13 PM
Hi @SteeleFamily The satellite footprint does not care where you are. It can only be your particular setup or is it extremely bad weather?
