Discussion topic: No satellite on all channels
This message was authored by IanF61 This message was authored by: IanF61
The status of my satellite is good, some channels, work correctly other say no satellite signal, I have rebooted my router and rebooted my skybox Q box but no difference
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: No satellite on all channels
You will need Sky to check the alignment/LNB of your dish.  Rebooting won't make any difference if that's the issue.
I am just another Sky customer and my views are my own
@IanF61  Your router has no direct link with channels delivered over satellite rebooting it won't help at all.
This message was authored by Daniel0210 This message was authored by: Daniel0210
@IanF61
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
IanF61
Thanks I will see how I get on the strange thing is that it was working fine yesterday
IanF61
All, I have discovered the issue one of the satellite cables on the back of the Q Box was loose, confused as to how, this is the first time I've used this forum so I appreciate your help... Thanks
