1401
This discussion topic has been answered Discussion topic: No satelite signal
This message was authored by: MrsACF
Re: No satelite signal
Probably those pesky Russians knocking out the satellite! I'm only partly joking by the way, I wouldn't put it past them.
This message was authored by: Turves
Exactly my thoughts
Re: No
@Tracy140706
With a “no satellite signal” message, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling,
▫️snow on the dish/LNB in winter
so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
If you are connected to a communal dish you need to liaise directly with your building management company or landlord who will have their approved engineers to contact direct.
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 adverse weather can affect the satellite signal and following such events wait times for an engineer will probably be significantly longer.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
This message was authored by: Dust+know
Re: Sky tv not working
Me too had a power cut  sky box was glitching did a reset now nothing.  According to service checker everything looks good
This message was authored by: hixx
Re: N
Erm... have you not seen the 3 page thread... NO SIGNAL...  LoL.
This message was authored by: Mellymoo100
Re: No
No signal anywhere in Uk by looks of it
This message was authored by: LiamP
Same issue here in Herne Bay Kent. They keep saying apps work but they don't either. Not going outside yet to check the satellite just got two grumpy toddlers that like to watch some dancing fruit on you tube 😄
Same here is cornwall...
This message was authored by: LB63
Same here (Kettering Northamptonshire)😩
This message was authored by: Gaza61
Again tried reset and nothing
This message was authored by: donks99
Can watch on sky go and can watch through it app, but not through the sky q box which seems strange.
This message was authored by: fedfan83
Same here yet you go to settings and there is a tick next to satellite signal but the screen says otherwise and I can't watch anything.  Not even had bad weather here.
Mine is occasionally for a second
going to unlocked but 0 signal strength and 0 signal quality
This message was authored by: pwince+bwian
Same here no satellite signal on screen but in settings says signal ok and locked, but signal dropping off every 15-20 seconds hope it's sorted soon
This message was authored by: Bristol
No sattelite signal
5:03 no sat signal,, even though Sky page says no issues in my area. I've restarted in case of a false negative, but still the same.
Sky comment required please
Answered - Go to Answer
