Discussion topic: No satelite signal for some channels
This message was authored by: Andy324
I have no satelite signal for some channels - not all
Re: No satelite signal for some channels
Work through this: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
@Andy324
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
