Discussion topic: No sat signal
Message posted on 02 Jul 2025 10:46 AM
No sat signal
Only get bbc no other channels due to no sat signal
Message posted on 02 Jul 2025 10:47 AM
Re: No sat signal
@Dean146
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Message posted on 02 Jul 2025 01:25 PM
Re: No sat signal
Just noticed you have posted the same on both the Sky+ and Sky Q boards. So which do you have as the answers will be different?
