Discussion topic: No rewind or pause on GB News channel
Message posted on 22 Oct 2025 08:54 AM
Cannot pause or rewind the GB News channel today, get a message on the screen saying not possible. All other news channels work ok.
Message posted on 22 Oct 2025 09:12 AM
Re: No rewind or pause on GB News channel
@LeeG
As it fixes a multitude of problems firstly try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
https://helpforum.sky.com/t5/Sky-Q/Pause-rewind-issue-16-09-25/td-p/5087031
Also happening on ITV 103, 4+1 204. Not getting prompt that programme started xx minutes ago with option to watch from start on app for these channels. Happened last month and appeared to be a Sky issue, see link. Need KevNewMedia who got involved last time but he's offline. Hopefully another Sky employee monitors this board.
